Trouble starting my LC
sebasti0n
81
LC got serviced a couple of months back, over the last couple of weeks i have noticed that occationally the LC wont start first time. After leaving it a minute it just about starts and coughs out a load of smoke....
Im assuming ive flooded it, and the smoke is the extra fuel burning off.
Just wondering why it has started doing this.....
One thing, I had to replace 1 ignition coil this week, but its still had trouble
starting today ....
Any Ideas......
sebasti0n
81
ok cheers, coolant temp sensor sounds interesting as it currently has a water pump leak..... going in thursday ( under warranty)
just wondering how this would affect the starting of the car though???
Also noticed that sometimes the idle flutters slighly between 600-700rpm..
Read on hear that its advisable to change all Ignition Coils if 1 goes.
would only replacing 1 give the problems i seem to be having ???
SEAT leon 007
59
BHAM
IF YOUVE HAD UR TIMING BELT CHANGED IT COULD BE THAT FUEL PUMP TIMING, needs to be adjusted, happened to mine and only had a problem starting in the mornings after that its cool. hope i helped
sebasti0n
81
cheers for that.... yes I did have the timming belt changed back in April... which is when I had the water pump changed.... will mention the timming thing to them... many thanks.
