Pepcox
32
8
Slovakia
I cant say from top of my head right now but there was also this:
in "Frt Sens. Drv. Assist" module:
HC_point_of_intervention from late to early_setting_over_menu
Emergency_assist_variante from Not coded to variante 4
djmartzian
30
7
@Pepcox , The above coding has noting to do with Active Lane Change Assist.
@giuseppearmran.randone, These are my notes collected from VW Golf Mk8 forum; below is also the coding that I've applied on my car (SK Octavia NX):
Original Source: MK8 Golf - Code List (English) (07-2023).pdf
Requirements:
Lane Keeping Assist
Travel Assistants
Lane change assistant ????
ACC
Park steering assistant - Control unit 76 5WD919298 5WA919298 or 5R3919298 (12 sensors)
Control unit A5 (front camera) at least 5WA980653D software version 3400
The system is activated from 90 km/h and on the highway.
Adjustments:
Control unit 09 [Tested SW: 0161] - Adaptations
BCM driver assistance turn signal functions:
Travel_Assist_Blinken: Active
Control Unit 44 [Tested SW: 1040] – Long Coding
Qfk_ma_function: Active
Control unit A5 [Tested SW: 3403] – Long Coding
HC_Variante: Variante_3 (OR Variante_5)
HC_mob_line: Coded
Reactions: Pepcox
Pepcox
32
8
Slovakia
Adjustments:
I dont even have those adaptations/coding in my units. Do you? (09: 5WA 937 086 AE 0175, 44: 5WA 907 145 1040)
djmartzian
30
7
Hello @Pepcox,
I wasn't able to code the Module 09(same software version as you), because I did NOT find the adaption channel.
But, I managed to set QFK function in Module 44(5R3907146A 2040).
Even so, I can't test the new function because my car(SK Octavia NX) is missing the Side Assit/RTA option. I need a retrofit first. :)
Pepcox
32
8
Slovakia
I see. I can't test it neither 'cause I don't have "D" software in the camera unit. Does anybody know if there is an "official way" to make it upgraded? I don't want to break the warranty by upgrading it by myself.
When I was asking dealer if they could update it they said that for my vehicle wasn't released an update yet so no. 🤷‍♂️ Probably because it was sold without Travel assist function.
Reactions: djmartzian
Feb 22, 2022
96
45
tell me what you want me to provide to understand if mine has everything you need, it certainly doesn't have Unit A5 with letter D since mine has the letter C
Feb 22, 2022
96
45
Does it require update only of 5WA 980 653 D or any other unit in order to make it work? I do have a same case in my car as mentioned above. The line change option is disabled but Im able to randomly see the option to change the lines on my screen :D It doesn't really works, looks glitchy and it is interrupted every time when it try to perform the manoeuvre. But it is interested that it sometimes appears even with the old C FW in the unit..
did you just update A5 to version "D" and carry out the encoding?
djmartzian
30
7
Update on the ^^:
Code:
I activated this feature on the Golf 8 2021 model year. Requirements: Side Assist, Park Pilot, Travel Assist. You need to update the assistant camera to version "D" and firmware no lower than 3403 + a new set of data.
More details in the below thread:
Feb 22, 2022
96
45
My a5
Feb 22, 2022
96
45
Update on the ^^:
Code:
mine is a Formentor my22 equipped with all the adas but does not have lane change since the a5 module is the one in the photo above with a C ending; Could you tell me exactly what I should do to get the lane change?
