Tracking & camber
May 31, 2008
1,247
So i finally had the tracking and camber done front and back. The thing is the car wasnt as low as i wanted it before i had it done. I was just wondering if it would be ok to lower it some more, or would i have to get the tracking and camber done again to stop the inside of the tyres scrubbing out?
pete-marshall
i'd say the back would be fine as its a solid rear axle so camber doesnt change through the suspension travel.
lowering the front a bit would give a slightly more negative camber but shouldnt affect the toe angle,
probably alright if its only minor adjustments!
May 31, 2008
1,247
Only about 10mm on the front and probably nothing on the back. I just want it that little bit lower on the front. So it should be ok?
Thanks guy :)
pete-marshall
ye would have thought so! though no one wants to be responsible!
tyre pressures etc will make a much bigger difference than that anyway!
May 31, 2008
1,247
Ok will give it a try, if i start seeing scrubbing guess i will just have to cough up the £25 lol.
May 31, 2008
1,247
Ok so I lowered her about 1cm today, seems to be a bit more bumpy. Might get the tracking and camber done when i get back from holiday. Just as a precaution lol.
