Towbar Wiring Schematic
Greg_S
Ive done a few searches and found that seat did a wiring kit 1M6-055-204-G 13pin plug for £100
I'm getting a standard wiring kit and im trying to find out which connectors i need for the rear lights to wire it straight up to them and the pin outs for it.
On each of the rear light housing there are two connectors with nothing connected to them and I guess it is going to be two of these that I must connect to.
Im sure that the connector housing and pins will be available through VAG and I can wire them up myself then.
Greg_S
The towbar has arrived at last and just goto fit it now. I read in the manual for the car there is a bulb on the dash to indicate that trailer lights are working so I'm assuming that the rear indicators for the trailer must come from a different feed, but where is it?
Nov 27, 2006
1,204
www.cardomain.com
Yeah, the light on the dash only comes on when the SEAT wiring is used cos it re-routes the feeds through those extra plugs you'd found
It's not VagCom enabled at all, it's just a group of different wires
Incidently, I've got a Leon wiring kit (on eBay at the moment) which I tried to fit in the Toledo, but the wiring for the tailgate is different between the Leon vs. Toledo so all the wrong lights came on :confused:
The light on the dash flashed, but only when I tapped the brake pedal :D
Got a towing relay fitted now - it beeps, but there's no dash light
Nov 27, 2006
1,204
www.cardomain.com
Oh, and mine's a UK car btw
AFAIK all SEATs (UK or non) have the bulb in the dash, you just need to buy the proper equipment to make it work ... not the pikey scotchlock solutions
The SEAT kit also comes with a new beefier hazzard switch to take the current drawn through the trailer wiring.
Greg_S
Do you know which pins do what on the kit? Im trying to get hold of the connectors separetly and make the kit myself since Seat what £45.53 for the kit.
Can you give me a couple of pictures of the connectors and will see if I can get hold of some. managed to on my audi when i re wired the coil packs
Greg_S
Didn't realise the hazard relays were that dear.
This is how I buzzed the pins out on the back
Nov 27, 2006
1,204
www.cardomain.com
Really need to get a scanner LOL
These are the plugs you need to swap in the boot, then there are the two that plug into the lenses (drawn above) and a couple to the numberplate lights (probably don't need to do anything with these though unless they run off that 2nd plug down)
Or here's a link to a proper kit on eBay for £30
230058399097 ;)
Greg_S
Cheers, will see what I can do, will take a look at bay later on
Greg_S
Managed to get by towbar fitted today, goto do the electrics properly yet. Only annoying thing was the westfalia towbar I have bought has a flip down bit of the electrics so it has to have side entry electrics so I need to get some silicone sealent to close up the hole on the side now. Think I will prob just splice into the electrics or use mini spade connectors to connect to the light cluster temp until I get the plugs.
