Toledo & VAG-COM 311
P-A
Hello, I'm trying to use VAG-COM 311.2 on my Seat Toledo 1.6 2002. The only code I get is from the radio (!), not very exciting. The other controls doesn't respond. Also, do anyone know which profile to use, I cannot find Toledo.
Any tip is welcomed.
BR Per-Arne, Stockholm Sweden
P-A
The interface is a OBD2 cable with USB connection. When I click 01 Engine, vag-com is trying for a while then I get "Controller not responding" message.
/Per-Arne
P-A
Maybe I'm using the wrong profile in vag-com. Toledo is not listed but there must be some other profile that will work, have only tried Leon so far.
P-A
I really wants this to work, the service lamp is blinking and I want to know whats wrong before flames are coming out from the engine :).
AndyC567
277
I use VagCom on my 2002 Toledo TDI without problems.
I also use the Leon profile for the full Controller scan, as you say, there isn't one for Toledo.
I get a few controllers responding including Engine, Radio, Airbags, Climate, Central Conveinience (locking, Alarm etc).. A scan is shown below..
I wonder why yours is different..
VAG-COM Version: Release 311.2-N
Chassis Type: 1M - Seat Leon
Scan: 01,02,03,08,15,17,19,22,35,46,56
Address 01 -------------------------------------------------------
Controller: 038 906 012 FK
Component: 1,9l R4 EDC G000SG 3357
Coding: 00002
Shop #: WSC 06402
VSSZZZ1MZ2R065xxx SEZ7Z0A1390xxx
No fault code found.
Address 03 -------------------------------------------------------
Controller: 1C0 907 379 K
Component: ASR FRONT MK60 0103
Coding: 0021505
Shop #: WSC 00001
Address 08 -------------------------------------------------------
Controller: 1M0 820 043 D
Component: 1M-CLIMATRONIC X0605
Coding: 00044
Shop #: WSC 00046
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 1M0 920 922 D
Component: KOMBI+WEGFAHRSP VDO V02
Coding: 05422
Shop #: WSC 00000
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 06402
Address 46 -------------------------------------------------------
Controller: 1C0 959 799 F
Component: 3M Komfortgerát HLO 0003
Coding: 00258
Shop #: WSC 06402
1 Fault Found:
01135 - Interior Monitoring Sensors
36-00 - Open Circuit
Address 56 -------------------------------------------------------
Controller: 1M0 035 186 D
Component: Radio 0001
Coding: 00403
Shop #: WSC 06402
End -------------------------------------------------------
P-A
What version of VAG-COM do you use and what kind of cable do you use?
P-A
I read in another thread that the com-port settings for the cabel in windows could be the problem. Vag-com works on certain com-ports and so on. I will test this today.
P-A
Things are happening now, here is my autorun using 1M Leon profile:
Controller: 036 906 034 CP
Component: MARELLI 4MV 3956
Coding: 00031
Shop #: WSC 40950
VSSZZZ1MZ2B001001 SEZ7Z0A1208487
Controller: 1C0 907 379 J
Component: ABS FRONT MK60 0103
Coding: 0001025
Shop #: WSC 40950
Controller: 1M0 920 802 A
Coding: 04106
Shop #: WSC 40961
Coding: 00006
Shop #: WSC 40950
Controller: 1M0 035 186 C
Coding: 00403
Shop #: WSC 00046
That a controller like 22 AWD is not responding is logical, my car doesn't got awd... But it would be nice with some additional controllers. Also, the service-indicator is blinking and I got some known problems with the car - but still no fault codes are found :(.
