plug it in there now to a vag com this wat it bringin up
Chassis Type: 1M - Seat Leon/Toledo
Scan: 01 02 03 08 15 17 19 22 35 36 37 46 56
Mileage: 190320km/118259miles
Address 03: ABS Brakes Labels: 1C0-907-37x-ABS.lbl
Part No: 1C0 907 379 C
Component: ABS FRONT MK60 0103
Coding: 0001025
Shop #: WSC 00046 615 1234567
No fault code found.
Address 08: Auto HVAC Labels: 1M0-820-043.lbl
Part No: 1M0 820 043 D
Component: 1M-CLIMATRONIC X0605
Coding: 00044
Shop #: WSC 00046
2 Faults Found:
00792 - A/C Pressure Switch (F129)
31-00 - Open or Short to Ground
01206 - Signal for Duration of Ignition Off Time
27-10 - Implausible Signal - Intermittent
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605 A
Component: 1L AIRBAG VW5 0A 0006
Coding: 12620
Shop #: WSC 00046
1 Fault Found:
01299 - Diagnostic Interface for Data Bus (J533)
49-10 - No Communications - Intermittent
Address 17: Instruments Labels: Redir Fail!
Part No: 1M0 920 921 B
Component: S5-KOMBIINSTR. VDO V03
Coding: 05412
Shop #: WSC 47886
Part No: IMMO
Component: IDENTNR: SEZ7Z0Y0772641
IMMO-IDENTNR: SEZ7Z0Y0772641
3 Faults Found:
01039 - Coolant Temperature Sensor (G2)
30-10 - Open or Short to Plus - Intermittent
01314 - Engine Control Module
01316 - ABS Control Module
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 00046
2 Faults Found:
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No: 1J0 959 799 AH
Component: 76 Zentral-SG Komf. 0001
Coding: 04097
Shop #: WSC 00046
Part No: 1J0959802F
Component: 76 Tõrsteuerger. FS0002r
Part No: 1J0959801G
Component: 76 Tõrsteuerger. BF0002r
Part No: 1J4959811C
Component: 76 Tõrsteuerger. HL0002r
Part No: 1J4959812C
Component: 76 Tõrsteuerger. HR0002r
4 Faults Found:
00849 - S-contact at Ignition/Starter Switch (D)
25-10 - Unknown Switch Condition - Intermittent
00943 - Heated Exterior Mirror; Driver Side (Z4)
35-00 - -
00912 - Window Regulator Switch; Front Left (E40)
00944 - Heated Exterior Mirror; Passenger Side (Z5)
35-00 - -
End ---------------------------------------------------------------------
Monday,05,April,2010,14:50:23:52320
VCDS Version: Release 908.2
Data version: 20100326
Address 01: Engine Labels: Redir Fail!
Part No: 038 906 012 AT
Component: 1,9l R4 EDC 0000SG 2815
Coding: 00002
Shop #: WSC 00046
Readiness: N/A
Coding: 0001025
Coding: 00044
Shop #: WSC 00046
Coding: 12620
Shop #: WSC 00046
Coding: 05412
Shop #: WSC 47886
Part No: IMMO
1 Fault Found:
Coding: 00006
Shop #: WSC 00046
Coding: 04097
Shop #: WSC 00046
Part No: 1J0959802F
Part No: 1J0959801G
Part No: 1J4959811C
Part No: 1J4959812C
4 Faults Found:
35-00 - -
35-00 - -
Monday,05,April,2010,14:57:58:52320
Address 01: Engine (038 906 012 AT)
14:57:56 Group 011
903 /min RPM
999.6 mbar Absolute Pres.
989.4 mbar Absolute Pres.
19.9 % Duty Cycle
