toledo indicators
Status
Not open for further replies.
R4 baby
Newbie
Nov 20, 2005
Hi all,
The indicators have stopped working on my V5, the hazzards still work and the parking sidelights still operate when key removed. Do the indicators and the hazzards use the same relay? where are the relays?. Can anyone shed some light on my problem please, not long had car, still trying to find stuff, fuse is good.
Dinosaur
88
The relay is the same as the hazard indicator. I am in the process of ordering a new one from dlever here from the forum.
Dinosaur
88
but if the hazards light work and your indicator stalk doesn't then it is probably your indicator stalk.
nmaher
you sure the relay is the same i know this is on a different car but on the volvo s40 the hazard relay is different from the indicator one cause i had to change it before
R4 baby
Newbie
Nov 20, 2005
All sorted now, to cut long story short, took to VW Autoaus-Kettering, they eventually changed hazard switch in dash and managed to break cup holder and stopped radio from working-which they said was already like it before they touched it-NOT TRUE !!.
Most impressed with Autoaus Kettering with only charging £85 for all that work !!
Switch 1J0953235J01C £13.60. (swopped over switch cover).
Status
