TIP + k04-001
joehirth
Rate me up baby
Apr 19, 2010
1,896
Woking, Surrey
www.facebook.com
Ordered a ko4-001 hybrid which is practically a ko3s I'm told
I've got a forge tip to go on it but I'm not sure I'm missing anything to make it fit?
Do I need one of these
http://www.forgemotorsport.co.uk/content.asp?inc=product&cat=190101&product=FMIBTH251
But the one For a ko3s turbo?
Need info as fast as possible.. Hoping to do it all on Saturday...
Thank you :)
If you have a Forge TIP on your K03 it will fit the hybrid. The hybrid is basically a K03 or K03S housing with K04 internals so looks and fits the same as a K03. You don't need any reducers or anything like that to use the TIP. :) It should be 45mm at the smaller end of the TIP.
Hope that helps.
Joe
mazzerati
Bags are for groceries!
Jun 27, 2008
1,980
Beverley, East Yorkshire
Sounds as if your hybrid has used the compressor housing/ inlet from the K04. RobbieC has a diagram on his build thread, around page 10 IIRC. Look for "custom tip" with a diagram of his K03S Hybrid.
Joe
Thanks Joe I'll take a look :)
And I could use the reducer yes seems like the best option ATM! Gunna ring forge see what they can do for me!
Got it from universal turbos :)
joehirth
Rate me up baby
Apr 19, 2010
1,896
Woking, Surrey
www.facebook.com
Post #256
http://www.seatcupra.net/forums/showthread.php?t=217772&highlight=k03s+hybrid+build&page=13
Effectively you could use the reducer that RobbieC used, turn it around and get a 45mm coupler (you would have to trim the Forge TIP though) that could be a poss. Otherwise you could make a custom TIP like I have done but it till cost about the same as the Forge one - I did it because it meant i could hide a lot of the ports and take off's. RobbieC did it in order to try and create more air flow although he claims the gains weren't worth the effort.
Here's a pic of mine:
