TIP and MAF Question
DJ-LIAMC
VAGisclean
May 31, 2009
656
Loughborough
Tried searching but no luck.Ok, ive cleaned my MAF with some electrics cleaner, dissasembled easy cleaned it (although it looked clean) but on the sensor i noticed that the 2 metal prongs sticking out didnt have anything between them, or is it supposed to be like that??
Also i noticed like a splash of oil in my TIP looks like it came from N75 valve Is this normal or is something wrong?
Ronin225
4,652
22
Worcester
I would remove your TIP and have a goog look to try and ascertain extact where the oil is coming from as its being sucked into your turbo
You will have a little of oil in boost pipes especially at low points like intercooler but i thought hardly any pre turbo
DJ-LIAMC
VAGisclean
May 31, 2009
656
Loughborough
ok i did an ecu reset (taking off battery for 10 mins) and now the fault light has gone off, does this mean the fault is a minor?
Also does anyone know if my maf is supposed to be like that in the first post ( cause i still dont know)
vwbassett
Joined the Dark Side
Aug 13, 2007
963
53
Surrey
All i remember seeing on my old MAFs was a thin wire between two points but that was a mk4 golf gti
