Madmile said:Not sure mate, get a engine rebuild but stick the td06 20g on. Dont bother with lp head etc. I reckon a tdo6 will break into the 400's on that spec.
ibizacupra said:so after you then Gary yea?
heard of something called nitrous ryanryan_s3 said:Although james made 440bhp on both of these.
if my god damn cold eventually clears up i'm planning a few runs at the pod on sunday. i'm itching to see the difference that the ihi does over nos! i'm sure terminals will be higher as i can hold it longer in each gear now 2 runs just ihi then 2 runs with nosryan_s3 said:i'm sure the 440 was without nitrous, so whats the plan with yours steve,nitrous on yet?
dry and sunny all weekend but bloody coldryan_s3 said:depends on the weather of course.
nope,drop sump and remove cylinder headryan_s3 said:quick question guys,would the engine have to be removed for rods and valves,i assume as no machining is needed(ie no pistons) it could stay in?
caney said:nope,drop sump and remove cylinder head
ryan_s3 said:anyway bill how much for large port and intake manifold?
not sure,don't think soryan_s3 said:thanks steve,did you have uprated main/big-end bearings?
so far so good,ihi turbo has completely transformed the car. i'm looking at stickier tyres at the moment as you can hear the f1's fighting for grip!vern said:how's the MRC map going mate, heard good things about them...
peaks at 28psi and holds 23-24 psi so quite aggressiveryan_s3 said:what boost are you running now steve?
