timing logs(020)
ryan_s3
1,270
I was told that i don't want to see more than 5 in block 020,i logged 7.5 on cylinder 4 which always seems to be more than the others.cylinder 3 seems lowest(maximum 3). 1 and 2 max was 6.This was logged in 5th gear if that makes any difference.I've been using some octane booster and wondered if this makes any difference?
Simon L
Audi TTS
Sep 24, 2004
1,253
Glasgow
I'd like to know the answer to this too.
I've read the Revo SPS guide and it suggests you aim for as low a value as possible when altering the timing.
But similar to you Ryan i see up to 7CF.
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
What map are you running Simon?
adjustable timing is ace if you have it - but in Jan you really don't want to see much / any correction since when it's the summer it'll pink like a bitch. (something I've heard on more than a couple of cars that have passed thru ryan's mapper?
ryan_s3
1,270
play fair now mork.I think there might be a reason for this and it's not down to mapping.
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
OK... what are you inlet temps like?
Either way - if nothing is 'wrong' then you really shouldn't expect this from a map that must work all year round.
can you cut & paste the logs in? be interesting to see how long it goes on for over the rpm range.
cordobabrendy
FOOORRREEE!
Aug 24, 2001
7,642
belfast
cylinder 4 is usually higher might be less air getting to it, bill has a manifold on his motor that i think was designed to do it equally...iirc (could be wrong)
ryan_s3
1,270
log of inlet temps with n75 duty,as you can see pretty good.I think it might be the water injection either not working or the service dummy topping it up with screen wash!Emptied and refilled now.Will do some more logging.
/min °C 0%
2640 19 1.6
2760 18 95.3
2880 17 95.3
3000 15 95.3
3160 15 69
3360 15 80
3600 15 81.6
3880 15 78
4160 15 75.3
4440 16 73.7
4680 17 73.7
4960 18 73.7
5200 18 77.3
5440 19 80.8
5680 21 85.1
5920 21 87.8
6160 23 89
6360 24 89.4
6560 24 89.4
6720 24 89.4
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
What fuel are you guys using?
I logged a stock LCR last night that was running 95 rather than optimax & that was pulling some serious timing correction in a similar pattern to Steve's - even with inlet temps @ 12C
Ryan - your inlet's look low, so if your water injection was just water - I can't see that would increase the octane rating. I don't think you need it at the moment...
Could it be you think you're buying something with higher octane?
Also - Steve's air flow logs look a bit low, 137g/s is about 20g/s than the 'best' ibiza's - but then the boost is lower too.
Simon L
Audi TTS
Sep 24, 2004
1,253
Glasgow
Always either use Optimax or Ultimate.
I have previously seen 150g/s, so not sure why its lower now. It's not stupidly low as to suggest the MAF is knackered.
ryan_s3
1,270
some more timing logs;
Cyl #1 Cyl #2 Cyl #3 Cyl #4 Engine RPM
TIME
CF CF CF CF STAMP /min
0 0 0 0 0.68 2600
0 0 0 0 1.28 2600
0 0 0 0 1.88 2720
0 0 0 0 2.48 2840
3 0 0 3 3.08 3000
3 0 0 3 3.69 3200
5.3 0 0 5.3 4.28 3440
5.3 0 3 5.3 4.88 3720
5.3 0 3 5.3 5.48 4000
5.3 0 3 5.3 6.09 4280
5.3 0 3 5.3 6.69 4560
4.5 0 3 5.3 7.28 4800
4.5 0 3 4.5 7.89 5080
4.5 0 3 4.5 8.49 5320
4.5 3 3 4.5 9.09 5560
3.8 3 2.3 4.5 9.69 5800
3.8 3 2.3 3.8 10.29 6040
3.8 3 2.3 3.8 10.89 6280
3.8 3 2.3 3.8 11.49 6440
3.8 2.3 1.5 3.8 12.09 6640
3 2.3 1.5 3.8 12.68 6320
intake temps;
Engine RPM System Voltage Coolant Temp. Intake Air Temp
/min V °C °C
2600 14.21 77 6
2600 14.07 77 6
2720 14.07 77 6
2840 14.28 77 6
3000 14.21 77 6
3200 14 77 6
3440 14.21 77 7
3720 14.14 77 8
4000 14.28 77 8
4280 14 77 8
4560 14.07 77 9
4800 13.79 77 9
5080 13.86 77 10
5320 14.14 77 12
5560 14 77 12
5800 14.28 77 14
6040 14.28 78 15
6280 13.93 77 16
6440 14.07 77 17
6640 13.86 77 18
boost and n75 duty;
Engine Speed Intake Temp N75 Duty Cycle Press @ Intercool
/min °C 0% mbar
2560 7 88.2 1130
2640 8 95.3 1270
2760 8 95.3 1400
2880 8 95.3 1530
3040 8 65.9 1700
3240 8 73.3 1950
3440 9 84.3 2390
3760 9 78.4 2510
4000 9 74.9 2530
4280 9 73.7 2500
4480 10 72.5 2490
4720 11 72.9 2470
4960 12 73.3 2480
5200 12 74.5 2480
5400 14 75.3 2490
5640 15 77.3 2480
5840 16 79.6 2490
6040 17 82 2490
6240 18 81.6 2470
6440 19 80 2450
6600 20 75.7 2400
Still getting 7.5cf around peak boost 4000rpm sometimes.
caney
600
ryan what the f**k does all that mean:blink: santapod feb18th rwyb till 9pm!be there:D
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
It means that the car thinks it's running race fuel when all it's got is optimax.
how about an ECU 'forced' adaptation to revert it back to the stock settings.
Feel
Veedubya 'velle
Jun 12, 2003
4,918
Midlands
[learning mode]
Even if it's that high on just one cylinder? 7 (edit: just realised I was looking at the wrong figure) deg on no 4 while the others are settling back? I take it no. 4 is the one at the RHS of the engine looking from the front?
[/learning mode]
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
pinking is no good no matter what cylinder it's on Phil, I'd turn it down if that's what you're seeing
Feel
Veedubya 'velle
Jun 12, 2003
4,918
Midlands
No, nowhere near as high as that - only ever seen 7 deg when I had it turned up to "11" (as in Spinal Tap).
Just wondered if all that pull on one cylinder is to do with too much timing or someothing else - bad spark for example?
Interestingly, on mine and other LCR's I've seen, you can have no timing pull what-so-ever at 3000-5500 (guessing) then all of a sudden you start getting loads (6-7 deg) above that. Is that "normal"?
