Timing Belt or Chain
ile
32
Please advise ,
it is about Seat Leon 2015 1.4 TSI 122hp
is it timing belt or chain?
thanks in advance
Woody_72
502
252
Northwest England
Just had a quick Google and what a can of worms! General consensus is chain but it's not clear. If you look under the bonnet at the left hand side of the engine, do you see a clip together plastic case covering the left hand side of the engine or does everything look metal and more sort of integrated? If it' s a plastic case it's a belt. If it's all metal and more integrated looking, it'll be a chain. You can sometimes see the chain through the oil filler cap but that depends entirely on where the filler cap happens to be located.
Rooster
1,188
326
Yorkshire
That should be an EA211 engine which has a timing belt, just replaced mine! Show us a picture of the engine for confirmation.
RUM4MO
7,967
1,059
South Scotland
Sorry if you posted about this elsewhere, but out of interest at what age and miles did you get the belt changed, thanks!
Rooster
1,188
326
Yorkshire
Car is six years old but only done 37k, timing belt kit Dayco KTB819 was only £70 from Germany, so doing it myself was a no brainer really. I also changed the serpentine belt and tensioner at the same time. You do need locking tools and a crank pulley holding tool as that bolt is tight!
RUM4MO
7,967
1,059
South Scotland
Good, my wife's Polo 1.2TSI is only coming up for 5 years old and roughly 30K miles, I can't explain why, but while I carry out many repair jobs on an engine, I have a keen desire to offload changing the timing belt to an Indie workshop - I can't really explain why I work that way, my loss!
Edit:- I'm guessing that the old belt and idlers and tensioners etc were still "as good as new" and the aux belt tensioner change was just done as good practice?
Rooster
1,188
326
Yorkshire
Hi, that’s understandable really, the cam pulleys are on a taper with no keyway, there are no timing marks, and apparently the pulleys are not perfectly circular either! The latter apparently to reduce load on the belt. Modern engines just get more complex, different beasts to when I started my apprenticeship in ‘73 that’s for sure.
I like to keep a rolling maintenance plan, although the car is low mileage, it does do a couple of Italy/Austria trips a year (or did until lockdown!)
Reactions: Woody_72
ile
32
Belt , already change it complete with water pomp e.t.c
Continental both belts and SKF water pomp i think is excellent combination
Reactions: Rooster
