Throttle sticking open on my LCR?
drue1
193
kent
Apart from the throttle body sticking open because it needs a clean, is there anything else that can cause this?
Othan a Good clean to the Throttle body. Cable might need some oil or if it still gets stuck get a new cable
dom b
What makes you think the throttle is sticking open?what symptoms are you getting?
Mar 3, 2008
807
sunny Devon
if throttle is sticking open on a lcr, thats the throttle control box under throttle pedal.
at least mine did that once or twice.... and then it never happend again????
Mark300zx
1,455
8
Surrey/SW London
Not sure if it is linked but the clutch sensor looks like it is playing up as well!
My symptoms were accelerating at 50 mph, took foot of accelerator and the car was still accelerating, no clutch use for a while before it happened.
dom b
If you press the clutch in does the engine rev to the limiter or to around 2-3,000 rpm?if its the later,could be coolant temp. sensor faulty,i had this fault.Vag-com is the way forward though!
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
do the revs flare up when you change gear?
common implausable signal on one of the clutch pedal switches
Mark300zx
1,455
8
Surrey/SW London
Yes it has done that a couple of times, right up to about 6k, the first one I thought it was my fault in going back to driving a manual but the second time I realised it was the car :)
How many clutch pedal sensors are there and are they all easy to change?
