Im having problems with my LC.... but as its very intermittent im struggling to get it sorted....
some days there's no fault other days when you start up, the revs flutter when your at a stand still, almost as if it is going to stall.... when this happens, when your booting it, you can feel the car hesitating....
Also find that when starting its worse if you just put the key in and turn on straigh away... If however you turn the ignition on, leave for about 5 secs and then turn the car on, the problem is less frequent.....
So do you think a Throttle body clean would fix this fault ???
