Throttle body?
cuprabaz
Racing 2020VT
Jun 22, 2004
2,357
Aberdeenshire
I've been getting a few throttle related fault codes and bizarre goings on.
Codes as follows:
18087 - Drive by wire - MIL circuit open
17976 - Throttle actuator(J336) mechanical Intermittant failure
17953 - Throttle Valve controller: malfunction.
Last night while giving it some, the car nose dived losing all boost and going down to 3 cylinders(ESP light on). turned it off then everything goes back to normal. This has happen a couple of times now. When my car got smashed the black plastic casing on the front of the throttle body got cracked so i think the above codes are caused by water ingress. Can these casing be opened or is it easier to replace the TB before i go hacking it to pieces.
Other unexplained codes, maybe be connected to the above???
16955 - cruise/brake switch(A) Circuit malfunction
16622 - Turbocharger boost sensor(A) circuit high input
16795 - manifold Abs.Pressure or Bar.Pressure range/performance
18010 - power supply(B+) Terminal 30 low voltage
17584 - O2 correction behind catalyst. B1 limit attained
16522 - O2 sensor Bank1, sensor2 high voltage
16523 - O2 sensor bank1, sensor2, slow response
Tony 156
468
Thatcham
Good plan, bit of duct tape, few cable ties and all will be good.
Plus save yourself a lot of money too, guessing there not to cheap.
Tony 156
468
Thatcham
Yes some one with the same view on life as me at last!!
Three things will fix anything, A hammer (biger the better) WD40 (fix all in a can) and a angle grinder (sparky sparky).
If all else fails, buy a new one.
cupra_matt
Audi Technician
Dec 15, 2004
1,362
Carlisle
Strange. I have never seen a problem with the FBW throttle's. Almost certainly due to damage caused by the bump, they aren't cheap either, around 250 + vat iirc.
cuprabaz
Racing 2020VT
Jun 22, 2004
2,357
Aberdeenshire
2 weeks ago i removed the TB to find it electronic parts were corroded due to water ingress(crash damage), cleanedt up as good as i could and filled it with silicone compound to prevent more water getting in. This never cured the wandering revs - caused by me messing with the TB a while back.
Bought a TT TB off ebay for £21 cleaned it up using electrical solvenet and scotch brite. job done. Back to normal now.:D
