throttle Body
Status
Not open for further replies.
Nev_LCR
Gone... but not forgoten
May 16, 2007
1,271
Ipswich, Suffolk
whats the best way to remove the metal clips on the throttle body, the ones that hold the black plastic cap on with the electricts under??
cheers
DarrenJ
Seat like you mean it!
Dec 3, 2008
470
Galway, Ireland
I just prised off the plastic cover with a screwdriver - mind you it did crack in a few places because I think the continuous heat makes the plastic very hard. After I got it off I just sprayed WD40 into the gears etc. I also replaced the air filter (if you're experiencing the alternating idling whic I was). This put an end to it. I understand this is a common fault on modern cars. I also sprayed a small amount of WD40 on the throttle butterfly when i had the air filter off to make sure it returns to the correct position for idling. Hope this is of help.
Status
