Throttle body realigning everytime i turn ignition on?
jat115
The other day I decided to reset my throttle body- re align it.
So i disconnected the batt for 10mins and reconnected it, when I went to turn the ignition on so it could realign it made a quiet buzzing sound- I guess its the bodys motor resetting- fine..
But it seems everytime I turn the ignition on it makes this same sound.
Is there a problem here and is it trying to reset every time i go to start my car?
Nov 2, 2004
9,335
South Wales
TBA doesnt happen if you disconnect the battery.
You do it by opening the bonnet and switching the ignition on, then go and have a listen for a high pitch squeel and possible a couple of clicks.
You've just cleared and adaptions.
jat115
I know its not the turbo cooling fan, cos I can hear that seperately.
Plus i dont think its the fuel priming either.
The noise is a high pitch squeeal that takes a while to stop and does a couple of clicks too.
jetsetjimbo
a.k.a James
Jun 12, 2005
630
J2 M5
I thought that was a throttle body re-alignment not resetting the adaptions in the ECU?
I thought that was a battery disconnect or vag-com jobbie....
flashbsd
i must admit, i can hear mine realigning about 5 in every 10 starts if i start the engine with the door open (cant hear it when inside) always wait for the squeal to go before i start (usually bout 30 secs) cos i dont want to have a half aligned one!
I know what the difference is btw on the noise ;)
