Throttle Body Cleaning..
sicupra
I aint far from you.
come see me and for a pint or two il sort it out for you.
Il come to you if the price is right.
dealers/tuners will charge at least £50 for a TBA il less than half that as your on here.
shout me if you want.
Private msg if you like. Whatever dude. :D
cmc
ohhhhh yes.
Sep 13, 2002
637
Glasgow
drue1
193
kent
so if i take the throttle body off and leave every thing connected clean well and dont touch the butterfly i dont have to reset anything ?????
Phillc
Love is....Yellow
Apr 23, 2007
4,170
20
Pershore, worcestershire
That is correct, if you dont disconect you dont need to do anything...well apart from bolt it back on to the inlet...and connect the hoses back on :D
shauncupra
59
Norwich,Norfolk
What i did with mine was turn the ignition on, then with a piece of wood jam the accerator open with a prop then the butterfly inside the throttle body will be fully open, sprayed carb cleaner past the butterfly and all in the inlet manifold then kept wiping it with good kitchen roll untill all was clean and dry , It certainly improved my idling and made it accelerate smoother also.:)
611
London
Guys, ive been reading about throttle body cleaning etc. im about to go and do it, but I dont know what cleaner to go for, everyone is saying carb cleaner etc. could someone point me to the actual product. i.e brand and name of what they've used or what is percieved to be the best.
Feb 24, 2010
611
London
Anyone?
traumapat
Leon Cupra IHI
Jul 24, 2005
5,925
sunny sussex
I've not heard that. I took the 4 bolts off and cleaned from behind so it all ran out onto a towel under it rather than into the manifold. You just need a gasket.
I'd imagine you'd need to chuck alot of the stuff though the engine before any damage could occur.
Feb 24, 2010
611
London
Was planing to keep it on and just spray n wipe kind of thing lol
LukeK
410
Preston lancashire
At higher revs when I take my foot of the accelerator my car revs a little. Mostly annoying when I'm changing gear because it sounds like I can't drive like the clutch is fCKEd or something. Isn't the clutch sensor by the way I've changed that. Would this be something to do with the TB? As I don't have a clue what it can be. I wish It was the clutch sensor :-(
