Fitted mines today - they look not too bad.
Thing is, fitting them was weird - I tried one way and the window wouldn't go up, it jammed on the seal then went back down.
The other way, which I've stuck by means they sit in fine but when the window gets nearer the stop they slow down a lot as its a bit tighter... is this normal - do you guys have the same thing?
Other than that I'm pretty chuffed with them
