Third Gear Syncro... Failiure??
Craig!
IHI Ibiza Cupra
Jan 6, 2005
1,876
Guisborough
www.vagcars.co.uk
Ever since I got my gearbox back after the box was rebuilt with the diff 3rd gear always seemed to have a little crunch at the high end of the rev range, recentlly it's been getting worse and worse and after today the gear just crunches and snags itself into gear.
So I'm thinking the 2nd to 3rd syncro has failed, anyone else suffered this? Does it do it much harm driving it with it crunching? It's fking typical meant to be going to the 'Ring on the 5th July and was just taking the car for its last run out before going!! :censored:
Feb 25, 2007
1,068
cheshire
Gutted for you....sound like the sycro like you say tho, or could be something they did after rebuilding the gearbox. I wouldnt say i would do that much damage but its not gonna get any better as all the metal will start getting round all the bearings n might damage them!
Craig!
IHI Ibiza Cupra
Jan 6, 2005
1,876
Guisborough
www.vagcars.co.uk
Well if I'm going to ddrive it on it i'll be giving it fresh oil before I set off, whilst I'm there and when I get back the box will be coming out... All i'm really bothered about is the crunch when shifting down, what is actually crunching?
Is it the syncro mesh or is it damaging teeth? Suppose either way if rebuilt it's get a whole new third gear no doubt.
Feb 25, 2007
1,068
cheshire
the syncro mesh looks like a couple of small discs with teeth around them. The discs are sat on top of each other, and another cylinder shape discs is wrapped around these discs which is then moved up and down these discs by a selector fork to selector a gear. The crunching is prob down to a broken tooth or somthing along those lines which is stopping it from meshing properly..i.e crunching.
It goes something like that anyway i think..im not clued up on gearbox's at all so someone will prob correct me :)
Yeah i would just get third gear replaced!
Craig!
IHI Ibiza Cupra
Jan 6, 2005
1,876
Guisborough
www.vagcars.co.uk
Yeh I'm not too clued up on the internals of the box so thats why I was wondering whether it's the third gear tooth actually crunching or is it inside the syncro, basically just wondering if it's OK to drive on it?
I think I remember Bill having syncro problems just can't remember if he left it til it failed or went and built the box straight away?
Feb 25, 2007
1,068
cheshire
i reckon it should be fine for abit! you have new oil in ther anyway coz uve had a rebuild so wont do as much damage!
reckon its the sycro itself
Black TDI Turbo
Shussssh Its A Diesel ...
Oct 2, 2005
1,175
North East
The crunching is the gears not slowing down to the same speed when engaging them and the teeth grinding together, this is normally the syncro.
Craig!
IHI Ibiza Cupra
Jan 6, 2005
1,876
Guisborough
www.vagcars.co.uk
Just been back out in it, going up the box feels fine, coming down the box is OK however every now and again you get a crunch... but it can be avoided!!
If you knock it out of 4th and hover over third when the engine speed comes down enough you can select third without crunching then just release the clutch to bring it back up the rev's.
Will give it a gearbox oil change to see if it improves things. Any idea where you can get Tru Blue in the UK rather sharpish?
h17och
the hunt is over. 460bhp
Sep 1, 2005
3,504
Dunstabubble
i got a year warrenty on my box! so if i were you i would just take it ring then if i gets worse just get it done under warrenty when you get back! ive if its totaly fooked wen you get bak it dont mater coz you got warrenty!
how much was your rebuild out of interest?
HoocH
