ADAMWIGGY
I have a problem with my leon cupra taking ages to warm up to 90 degrees. I have had the temp sensor replaced with a nice shiny green one but problem still there. no faults on vag com at garage.
Done a little searchy and seems that there is a good chance thermostat is stuck open. ive found the diagrams of cooling system on here and it looks like its in the housing that the bottom rad pipe goes into, under the intake manifold/throttle body right next to the alternator.
I have two quick questions please if you can help
1: am i right is it where ive described/ and
2: looks a real bugger to get at. is it easier to drop off at garage and pick it up all done.
thanks hope someone can help or point me in the direction of a guide etc... many thanks.
ps i have used the search before you all start screaming at me.
