Cupraloon
A little while ago, i fitted an S3 lower brace, and had problems with one of the nut inserts stripping the thread, having to drill it out, a satilyboy kindly sent me a couple he didn't need of the bigger type with the in built washer.
Any hoo, i fitted these a few weeks ago, and i've gone to re-tighten them today, to a higher torge than the 50ft ibs that they were set at after reading that one of you guy's had done his to 80ft lbs, and...... guess what the offside one's thread was iffy again, so i had to drill it out yet again and fit yet another new nut insert and bolt.
And tightening them up again, firstly to 40ft lbs then went to do them to 50ft lbs and as i was doing this, i could feel the thread just starting to pull again, so left it at 45ft lbs
I even turned the brace round 180 degress incase i had it the wrong way round cos i noticed it is cranked at one end where the slotted hole is, and i had the slotted hole on the right hand side of the car, so now it's on the left and still bloody problems....
I just cannot understand why this is happening i'm not putting anything on the threads to cause this like copper slip or nowt else, just tightening them up as per the fitting guide, so it's a mistery......
Any engineers out there who might have any ideas's why this is happening, no one else seems to be having this perticular problem at least i've not seen anything on here about it...
Any way think i'm just going to leave as is, now at 45ft lbs and hope it's enough to stop the bar shifting, which would make having it a bit of a waste of time...
