The Inevitable has happened.....
CORBY
272
Sunderland & Washington
.....Yes as some will know I got my car remapped by Angel Tuning not too long ago, and the clutch is slipping. :cry: I'm just putting this thread up to see what my options are? Can anyone help me please? :)
mrcoyote
See no evil...
Jul 26, 2004
2,624
Your options are a replacement OE clutch and drive it properly or an uprated aftermarket one such as one from Sachs or similar. Pretty sure this has been discussed in the past, so do a little search for it.
Ad Lav
vRS...
Nov 10, 2006
4,230
Kent
Sorry to hear that mate, start driving it like a granny it might last a bit for you to save up!
Change down a gear before booting it?
CORBY
272
I'm gutted like!! Yeah I'm going to drive it proper granny style. Ad, you mentioned about a sachs clutch before, whats the craic with that? Its only just started slipping.....how long will it last, taking it easy? I've had no past experience with clutch slipping!
Oct 12, 2005
1,013
I have a sachs and a very powerful map running 450nm of torque and the sachs copes fine...good bit of kit. Some say its exensive but at least it means you can drive your car how it should be driven!!!
Nath.
The Gentlemans Express
Jan 1, 2006
8,620
16
EASTLEIGH, HAMPSHIRE
IMO it's no good remapping a 130/160 tdi and then needing to baby it at low revs, low rev range torque is what TDI's are all about :shrug:
Oct 12, 2005
1,013
I got mine in a group by from JBS. It was around 650 all in. Normally there around 730 fully fitted! Best to speak to Mike.
DIFT
Torquing all the Torque
Oct 8, 2004
1,546
Kent/London
Ive done 45k on a slipping clutch, an no I havent granny'd it. just not floored it below 2500-2700. Its fine for the rest of the rev range... just not the torque spike at the start.
CORBY
272
Cheers lads I've emailed JBS, so I will hopefully make some head way! I'm leaving it till the last minute like! Dift, I'll try and see what it's like flooring it in the higher range 2500-2700rpm see if it slips then! Cheers! :)
DIFT
Oct 8, 2004
1,546
Kent/London
by all accounts Angel push there maps quite a bit... not that thats a bad thing. But even with it turned down, would it be all that much different from a standard map?
CORBY
272
But its only at 280 odd lbs/ft I thought it would have lasted longer than this. I haven't used it all weekend I'm too scared! Could the clutch just stop working at any given moment?
Nath.
Jan 1, 2006
8,620
16
^^^^no, it will just slip more and more and start to smell like dog farts until you can't use any power at all and just slowly becomes undrivable
Ibiza 130 tdi
Black Magic
Jan 15, 2007
6,275
Somerset
i have a helix clutch fitted to my car and its great! a bit more savage than the standard but holds the power/torque great, allards supplied and fitted the clutch for £360.....
:-o
I was done! :( Thats a bargain price!
Hope you have better experienes with clutch than I did! :cry:
