stoneyfordNI said:
do u know dan if the smoke is coming out of the exhaust , or just from the back of the car , could be a exhaust manifold gasket or something like that , hence the bulkhead being sooted,
another 2p worth
This is a list of the things they did and changed:
service set (exhaust gasket, inlet gasket, pd/oil, oil filter, nuts,bolts,brakets) £90
modified intercooler pipes inlet to forge intercooler and turbo outlet to intercooler £58
Allard inlet adaptor (replaces EGR unit) with seal, bolts and adaptors for boost take off. £49.00
tweek the file or shall i say mapper tweeked
the fitting of the gauge
£25 for the fitting and the parts to apply the egr fittings,
Then of coasre they fitted the turbo aswell, and copied the map off the old ecu from mikes car, and tweaked it because mine wasnt getting as much air as his, hence why im getting rid of the dynatwist and will upgrade the rest of the intercooler pipework.
