4candles
I used Cruise Control today for first time. It worked fine, but the dash warning lamp did not illuminate. When i got back home I checked the lamps illuminated when key is first turned and still not all lamps were on, only some come up. (i.e. door open warning lamp does not illuminate on the key turn test, but does if i open the door).
At the moment seem that following lamps do not illuminate on the initial key turn :
Cruise Control
Washer Bottle
Brake Wear
None of the lamps in the Rev counter light up, but all work (cann't test the 'bulb failure' lamp)
On my old CMAX, there was a special 'Vulcan Death Grip' that a full dash lamp test and also full guage swing test. Is there something similar for the Altea so I can see if its just a bulb, or something else before it goes back to dealer.
Cruise Control
Washer Bottle
Brake Wear
