i don't know what the problem is...The sensor indicates temperature very wrong...outside are 30degrees and its only indicate 5. I must change something? It's the sensor or a fuse? My car its a Cordoba 2001. I have no idea... Please help!
Probably need to replace the temperature sensor which is, if the same as an Ibiza, under the passenger wing mirror (might be the driver side in your case as I see you are left hand drive)
Tnx 4 advice...However I'm not a very good english speaker so...I still don't know where this sensor is located. Under the car...under the mirror...or under the wing Can u draw me a map?
