temperature gauge
gear_1052000
sometimes when i start my car the temperature gauge stays at the bottom and the red light flashes!!!
and sometimes the gayge just doesnt work at all it just stays on zero even tho i have just drove 25miles
any1 got any advice ???
karl.w
methanol junkie
Oct 26, 2005
606
same thing happened to mine
It was the coolant sensor needing replaced
gear_1052000
yeh the engine runs very hot when the gauge works it stays on 90
how much was the sensor matey???
karl.w
methanol junkie
Oct 26, 2005
606
about 25 quid for the sensor and about the same to get it fitted.
has your mpg been lower
gear_1052000
yes i have got a thread on the go at the moment about my petrol!!! me dad could fit it lol!!!! does it affect the mpg then???
karl.w
methanol junkie
Oct 26, 2005
606
yeah it will make your engine over fuel as it thinks that its not warmed up yet so it puts in more and more fuel to try and get it up to the correct temp
sounds very like what was going on with mine
it took mine back to seat and they checked the faults on vag-com then fixed it straight away
karl.w
methanol junkie
Oct 26, 2005
606
you really got to get the fault codes read to no for sure.
could be a number of differant things but as your having problems with the temp gauge then i would say that its more than likely the coolant temp sensor.
acidstrato
My Fast says shut up!
Dec 9, 2004
5,942
Newport, South Wales
exactly!!! u really should have done more research before spending money!
theres actually 2 sensors!
the most common one to go is the one inside the coolant bottle, which requires a whole new bottle not a sensor, the other sensor is on the pipes on the side of the engine
gear_1052000
check this item 4652495383
for the money i thought even if this isnt the problem its a good buy
gear_1052000
well cant go wrong for a tenner can you lol!!!!
i will top it up see if that helps!!!
what was the original sensors prone to going wrong??
