Temperature control problem
May 30, 2002
2,050
Bedford (innit)
Ok I start my car, it warms the car up and everything is ok for about 1/2 hour and then all of a sudden the air from the vents gets very cold and stays that way, only way is to change temp to something like 26oC to get it warm again.
Had a search but couldn't find anything related to this?
It happens with air-con on and off also.
Anyone else experience this?
flashbsd
hi mate, first port of call try pulling the battery off, sounds like a sensory problem to me.
Mine doesnt get warm unless you have it on 28oC or HI, anythign below that is freezing cold, same with ac on or off if its any use. Is your outside temp gauge reading ok?
May 30, 2002
2,050
Bedford (innit)
Er.. Pardon? :whistle:
Yep outside temp gauge is reading ok.
So no solutions to fix it then?
flashbsd
i think rhumber had his changed not so long ago if im correct, i've not found a solution mate, apparently something to do with the external temp sensor, but if its reading ok i'm not sure :)
Pm in yer inbox rhumber ;)
May 30, 2002
2,050
Bedford (innit)
claudefrog said:
how many miles on your car? has the waterpump been changed yet? they have a habit of breaking up and one of the symptoms is not getting heat through to the cabin
Yep, cambelt and water pump changed recently.
Maybe I need to check the coolant level again as I know someone said that the level goes down after water pump is fitted?
Just to add to that it does stay warm for 1/2 hr and then gets cold.
