Temp Sensor?
Tdi_sport_JT
My Tdi sport started to read all sorts of random temps for a few weeks (on the on-board computer) and now doesn't work at all! Is it just a sensor that needs replacing? If so where is it located?
May 2, 2006
2,758
not too sure where it is on yours, but on mine its on the passanger side of the engine in a water hose, you will see a green plug with a electrical connector attached
and if it is the same.... i have a spare :)
Crafoo
Crazy Fool!
Apr 30, 2005
5,498
At home
If it's the outside temp sensor it's been covered loads on the forum, a quick search will find you all the answers you need, but as lemonslap says it's in the passenger side wing mirror.
May 2, 2006
2,758
i should really read posts properly :redface:
if its on your on board computer and not your water temp then as the peeps have said, passanger door mirror underneath you will feel/see a small nipple, thats it
replacing it is simple
Tdi_sport_JT
yeah its the outside temp, thanks for the advise guys!
