Temp Sensor
argyll2bikes
Hey man temp gadge doesnt work when the car idles for a while it will creep up i have changed the coolant temp sensor but still have the same effect any body have any other ideas?
Oh what is the thing on the radiator with the wires coming out of it?
cheers chris
argyll2bikes
I changed the green one at the right hand side of the block.
ok the fan switch is working then because when u leave it idling them cadge goes up and eventualy the fans switch on. but does the fan switch control the temp gadge?
cheers chris
GTV
Veggie powered TDi's
Feb 16, 2008
479
Cambridgeshire
no its nothing to do with the fan sensor, do you know what engine you have, normaly the sensor has 4 wires going to it, let us know the engine code and we can tell you for sure.
Skeelsie
Hi I have the same problem with mine so would also be interested in any help you could offer...
Engine code is a AUD it's 1.4 16v 75bhp.
Changed the expansion tank bottle with no effect so far.
Skeelsie
Got a new sender today, gauge has now popped back into life.
Green one on the passenger side of the engine block, £30 inc VAT and an O ring from VW.
bigste85
help needed
hi all am new to all this i have just bought a cordoba vario se 1.6ltr i have ot a few problems the temp gauge wont work it moves when i start the engine to the firt line then wont move fom there and my revs are sitting at 1100 rpm is this normal if not how can change this please help mot up next week can any one help thanks in advanced
coolypops
Tastes like chicken
Feb 14, 2009
146
The Emerald Isle
sorry i know this is off topic but where do you find the engine code on the 01 tdi cordie as cant find it on chassy plates etc.????
and big ste you need to change the coolant temperature sensor on the right hand end of the block. Its held into the thermostat housing at the back by a clip and can easily be removed.
rednexx
cheers chris
Hi there had same probs with my vario.1.69( alm engine code).found the thermostat housing cover damaged internaly causing the stat to jam open and the temp guage to stay cold,Two 8mm headed self tapper bolts hold the cover in place with an o ring to seal it.
5min job&now she runs fine
perks
87
To the OP it sounds like your thermostat. The housing can sometimes break leaving the stat permanently open. GSF do a stat and housing for around the 15 quid mark. If you look up my previous post I had the exact same problem and by the looks of it we;'re not alone. It's pretty common.
