Temp sender location
m_zafar
205
Have had numerous problems with the idle of my car, it also statters and revs all over the place. Replace the MAF 3 times however this hasnt sorted the problem. What to euro car parts and got the temp sender as its been recommended by this forum to replace. Its a 4 pin domponent however i have no idea where it goes! could someone please assist me here?
Part: TEMP SENDER 4 PIN GREEN
Part number: 460441610
ADAMWIGGY
Hi the temp sensor is located on the right hand side of the engine in one of the water pipes. there is a plug going down on the top of the sensor and it is held in the pipe by a horsshoe clip.if you look between the battery and engine block you should spot it. these are a common fault and i believe the original sensors were black in color whereas the updated ones are green hope this helps.
benjiwales
benji
Jan 29, 2007
297
Penybont
As above, take off both your engine covers first.
Changed mine Sat, very easy.........just remember that you engine should be cold:redface:
It's the green sensor shown here (mine was black)
m_zafar
205
nice one mate, found it, changed it and the car car is finally running smoothly. I dont get it, way would the engine rev all over the place if the temp sender is gone? what link does it have with the maf (as when i disconnected the maf, the problems went away)?
traumapat
Leon Cupra IHI
Jul 24, 2005
5,925
sunny sussex
the fueling is different on a cold start up... so i guess if the temp sender sends an intermittant reading and everything leaps about. perhaps disconecting the maf pulls everything to a safe lvl and temp readings get ignored too?
just a guess...
hope your mafs ok... mine went a week after replacing temp sensor :D
m_zafar
205
ive just put in a new maf, is there any chance that the new temp sender got potentially screw it up? If so, ive got a spare one lieing around
