PJ_TDi
Its Thwaite
Jan 1, 2008
152
Wiltshire
Hello all,
I've come to the conclusion that I think my temp sensor is reading incorrect. Last night my friends Golf and Audi A2 both read -2 degrees, mine read -6. As a result, any setting above "LO" inside the car is warmer than it should be. So I'm either roasting at 18 degrees or chilling at LO! :lol:
Is this because it would be over-compensating, thinking its colder outside than it actually is?
Any help as to what can be done would be greatly appreciated, cheers guys :)
Thermostat possibly?
Ive just changed 1 on my sisters Lupo. As it had a similar problem.
There is an internal temp sensor that it takes for reference so i doubt it has anything to do with the ambient temp sensor.
What I would suspect is there is a fault with the mixture flap motor, a scan with VAG COM and reset the motor would be a good start. See if it goes through its full sweep without sticking.
