Temp guage gone mad!
NowGottaIbizaMk5
375
Beverley
My temp gauge usually goes to the middle position - 90degreees - within 2 miles of driving.
The last 2 days it has stayed on the cold, 60 degrees, setting for up to 14 miles before moving, fairly speedily, to the middle, normal setting.
Today it was fine after 4 miles then dropped back to the cold reading and then, 8 miles later, decided to go the the normal middle position.
Does this sound like the thermostat is bu66ered?
A neighbour suggested that I use Radflush to clear out any rubbish and then flush the radiator and refill. Would that help or juts be a waste of time if it's the thermostat that's died?
Pulsebassuk
BASS MAKER
Jul 15, 2004
334
Colchester Essex
hmm that sounds like what happened to me. My firends cupra got to 90 fairly quickly and sticks there no matter what. mine used to take ages to get to 90 then when I was on a motorway it used to go down maybe because of the air hitting it i dont know. Now I have recently upgraded to a nuespeed thermostat and it all seems to be fine again ie: getting to 90 quickly and staying there. so maybe it is ur thermostat
NowGottaIbizaMk5
375
Beverley
O.K. seems to be about £9 for one. I'll look into it. Is is safe to do 500 miles in this weekend or do I have to put up with the wife's car instead?
Shytot
141
Where is the thermostat out of interest as my gauge is pi$$ed up I swear,
NowGottaIbizaMk5
375
Beverley
Yep - I get hot air through the heater.
will try top rad pipe tomorrow
Temp gauge has been perfect since I threatened it with being attacked with a screwdriver!
NowGottaIbizaMk5
375
Beverley
O.K. thanks for that Mr. D... maybe engine temp sensor then.
I get hot air through the heater and the top radiator pipe gets hot.
The needle behaves itself some days, on others its moves normally and on others it drifts up and down as it pleases.... I wonder if I could get it to synchronise it's movements with the rear wiper going off by itself - now THAT would be an impressive mod!!!
sparkie1984
sparky
Aug 17, 2008
1,005
you could try vagcomming the dials mate?
i did mine the other day, was fun watching the speedo hit 160 lol, not sure if it would show an error code, but worth a go if you have it
sparkie1984
sparky
Aug 17, 2008
1,005
lol, there was s erious suggestion in there by the way mate, just threw in the 160 as a little fun extra :D vagcom wil let you read any faults with the instrument cluster thats why i said it
May 29, 2008
675
Aberdeenshire
i know ths in the Mk3 section and i run a mk4 cupra, but last night driving home my car starting beeping at me...thinking it was the petrol beep...i looked down and my temp was just about touching 130 degrees!
Scared for my car i phoned AA, coolant level hadnt dropped no signs of the head gasket gone, he jumped in the car and found that the heaters were always blowing cold.....his suggeston....thermostat fooked! Would he be right in saying this guys?
Thanks in advance....and sorry for the hi-jack, need to get the car back on the road by tommoro for work :(
s1l3nc3r
ASBO car.
Jun 30, 2008
1,558
essex
not to sure if its the same on the mk4 but on the mk3 the normal places to check are fuses ontop of battery water pump or thermostat...hope that helps.
May 29, 2008
675
Aberdeenshire
very similar....got the fuses ontop the batt, but at 1st glimpse they look ok!
Water pump seems to be working....took the coolant cap of and you can see a constant flow through it!
Going to get a new thermo tommoro and see if that makes any diff!
