Taken from TD's K03S spec sheet:
MD349 High flow K04 2275 Spec Compressor wheel, C.N.C. re-profiled compressor housing,
360 degree thrust bearing, modified watercooled bearing housing, cut back turbine blades,
lightening of turbine wheel for faster ‘spool up’, modified turbine housing, up-rated twin
turbine seals. Other ‘blueprinting’ modifications. APPROX 240-250 BHP
Absolute Maximum recommended boost level – 18-20 P.S.I.
Please Note:
This turbocharger will fail in the thrust assembly if the maximum boost level
recommendations are not strictly adhered to as this unit it not designed to operate
beyond these parameters.
MD445 K04 turbo with Hi flow K04 compressor wheel, cnc machined compressor housing , large
trim K04 turbine wheel, lightening of turbine wheel for faster ‘spool up’, cnc modified
turbine housing, ported wastegate, uprated turbine seals. Other ‘blueprinting’
modifications. 12 psi Uprated actuator APPROX
280- 300 BHP
Absolute Maximum recommended boost level – 24-26 P.S.I.
Please Note: This application needs exact engine management settings, free flow exhaust system
and front mount intercooler to achieve these horsepower figures, however, the
exhaust manifold is the limiting factor in achieving any real worthwhile gains and
would need to be changed to get maximum benefit from the turbocharger.
Please note: - All specifications are for reference purposes only and are subject to change by Turbo
Dynamics Ltd. without prior notice. All boost pressure recommendations are subject to
engine condition and preparation. Modifications to the engine can affect the performance
and reliability of the turbocharger and the related performance figures. For further
information please talk to our technical staff who may refer you to one of our
recommended tuners.
