engine coolant sensor part no for leon/tolly
http://www.seatcupra.net/forums/showthread.php?s=&threadid=29427
Originally posted by sssstew
EGR mod problems with MY 04 TDI's :-
http://forums.tdiclub.com/showflat.php?Cat=&Board=UBB13&Number=665143
prc said:A pic with relevant part locations on a tdi..
Excellent Paulo, now I know where my EGR valve is....prc said:A pic with relevant part locations on a tdi..
muddyboots said:Excellent Paulo, now I know where my EGR valve is....
Is this a non-PD engine, if so it might be useful to do a similar diagram of a PD engine, guess there must be some slight differences.
Referring to the parts as:
Front inlet -> Adaptor -> Pipe -> Airbox
...where the Adaptor & Pipe are the bits being changed, this is how I did it:
1) Remove cross-head screw from airbox, pull old pipe out of airbox so the end is free
2) Remove 2 torx screws from front inlet, lift whole assembly out.
3) Prise front inlet off of old adaptor & hose. Chuck the old adaptor & hose.
4) Fit new hose into airbox and refit the crosshead screw
5) Clip new adaptor into front inlet
6) Refit front inlet & new adaptor using 2 torx screws (whilst pushing new pipe down out of way)
7) Bend the new pipe over the new adaptor and push together, pretty fiddly, requires a fair bit of bending of the pipe (which is quite flexible).
