tdi boost
strugers1
hi people how would i be able to turn the boost up on my 130tdi leon??and if its ok or possible to do so how do i go about getting it done??
devonutopia
fabia-lous
Mar 30, 2004
1,200
Exmouth / Exeter
You can't just "turn it up"
If you've been remapped by Jabba they will probably tweak the mapping to suit whatever you want the car to do. I doubt they'll charge you for another map too - I expect they'll just charge £40 per hour or so, to cover Mike's wages, and the dyno costs.
strugers1
well i getting one of there hybrids in august so ill just wait till then i cant go all the way up there just for a tweak!! devenutopia a quick question now i have a front mount clutch and green cotton air filter after my jabba hybrid what are the realistic power gains ill get for my leon??
jonjay
50 Years of 911
Jun 27, 2005
5,843
Essex
Clutch will be able to take more torque so it will hold the power the turbo hybrid will give. Depends what turbo they are putting on as to what power gains will be. Do you know which one is it?
strugers1
to be honest i am not sure it just says hybrid turbo so not sure they say the turbo with the custom map will give it 220 plus but just wondered if ill get an more
devonutopia
fabia-lous
Mar 30, 2004
1,200
Exmouth / Exeter
220 is realistic - Are you still running the stock clutch? I would recommend getting an uprated one (eg Sachs) asap as the stock clutch will not handle a 220hp Jabba map for very long at all. I ran 221hp with a Jabba map, but using Allard's VT2, FMIC and a green filter.
strugers1
yeah got the sachs clutch already fmic green cotton filter then jabba hybrid so hoping for 220 what lb ft torque do you think ill achieve??
