Taking out the cd player Ibiza
kojack
Hiya we have a 2005 Ibiza which we want to take out the CD player & replace it with the wifes Panasonic one we have.
The surround around the cd player is it easily removed, does it just clip in & pull out, I don't want to damage it trying to pull it out.
cheers
joop200789
330
Barnsly
ther two little slots under the furthest right and left hand buttons, in there is the release ctach for the unit, al i used was two strips of cut up morrison miles card inserted then it pulled stright out
hope that makes sense and helps
gaz
kojack
Hi Gaz, thanks for the reply, im sure it will make perfect sense when I go to take it out.
I also have a morrisons miles card I can cut up :)
cheers
kojack
Bugger I see the slots your talking about the right site seems to have a spring feel to it as I push the slim strip into it, but the one on the left seems dead no spring/release feel at all any other suggestions should I try a harder strip ? :confused:
cheers
stezo2k
Anjuna Monkey
Mar 15, 2008
2,804
Dudley
yeah i would try something slightly stronger, i think i used a thick piece of plastic myself
try not to force it though if you can help it
________
Big Tits Webcam
