T-Bolt clamps? size question
jamiebennett81
looking to replace all my clamps with t-bolt clamps
however with t-bolt clamps, there is not the size variation that you get with normal hose clamps
so for example, I want to replace all the clamps on the FMIC setup
is it 63mm off the PA FMIC setup? if someone could confirm please
so looking at the t-bolt clamp sizes, which ones do I go for?
64-67mm (taking into account the thickness of the samco hose)
http://cgi.ebay.co.uk/ACE-T-BOLT-HO...s_SM?hash=item3a4e37be19&_trksid=p3286.c0.m14
or this one (but this will prob struggle to fit)
60-63mm
seems to be less of a variation in size with t-bolt ones?:confused:
jonjay
50 Years of 911
Jun 27, 2005
5,843
Essex
Like me for example, my diameter tubing is 60mm, the swaged edge is 63mm so I am guessing I would need 64-67mm clamps as the silicone will increase the diameter??
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
if the pipe is 63mm OD the silicon pipe on top takes it to 74mm od on the one i measured here just now
jamiebennett81
So the clamps from roosemotorsport 73mm - 79mm will do the job for replacing all my old clamps for all the intercooler pipes then?
jamiebennett81
No problem, they do other sizes singally to if you want to replace the one directly to the turbo.
cheers mate
had five minutes to check over my pipework tonight. The pipes connecting to the FMIC are mushy as hell, and the bumper still needs to be cut away more as they are cutting into the pipes, and I have spotted a pin sized hole (I think its gone all the way through) which I think is causing some issues of course
the pipes supplied with the PA kit are of poor quality, but it gives me an exuse to get some nice shiny red pipes to show off at the front:D
