swapping clocks HELP!
sirjimalot
JIM-MAN
Aug 10, 2005
534
County Durham
i read that when u swap clocks u need to recode the immobilizer in the clocks, to do this u just need to do an ECU swap, so i did it and the clocks still arent recoded, anyone no whats up or give me any advice ? cheers
sirjimalot
JIM-MAN
Aug 10, 2005
534
County Durham
just clocks, everything lights up fine, starts for the 2 seconds before cutting out, and the warning light with the key inside the car keeps flashing,
even after ive done the ECU swap to recode them,
Nov 27, 2006
1,204
www.cardomain.com
Have you swapped the transponders between the keys ? (or swapped the ignition barrels)
Didn't connect the power up with new clocks and the old ECU in did you ? :headhurt:
Uwe@Ross-Tech
392
www.Ross-Tech.com
If you swap instrument clusters, you need to match the cluster to the ECU, and you need to match keys to the cluster. Procedures for all this are on our website, but to give you the right ones, we need real details about the car, preferably in the form of a complete Auto-Scan.
-Uwe-
