Nov 30, 2024
Hello,
I know this topic has been discussed or is being discussed here but everything is with automatic transmission and right-hand drive. I want to install a subwoofer and amplifier in my Leon mk3 ST FR MANUAL transmission. Does anyone know where to run the cable from the battery to the interior of the car? I have a clutch pedal so there is no free passage on the driver's side. I came up with a way near the fender where there is a plug on the door that leads to the door pillar where there is a handle to open the hood.
Thank you soo much
Take it thru the firewall rubber then run along passenger trim (plastic over carpet edge) under rear seat into boot, if you’re local to brum I wouldn’t mind doing it for you
