Sub install please help
wilko1
Hi folks, I have just purchased my first ibiza cupra mk4 in yellow and want to get the stereo sorted soon.(sub and amp)
Was wondering what the best way to wire in a sub and amp in is?
Is there a set of line outs on the stereo???
Any help appreciated guys.:)
Mat
you need some phono converter things. they connect to the rear speaker cable at the back of the standard HU, and convert that into 2 outputs that you need for the sub. Then run the power cable from battery as normal, earth it, and wire the remote wire to either ignition or back of HU also
paddy1987
hi i have just bought an mk4 ibiza and also want to put a sub and amp in and have been told they can connect it to the standard head unit bt will the amp blow out the standard speakers?
Adam R
Diesel ISN'T a Dirty word
Mar 5, 2007
2,851
lee in the solent
yes you 'could' blow the speakers up with the amp installed but so could i.. you just modify what level you listen to your music at... also it wont hurt upgrading your speakers as they are a weak point with seat's
