Stuttering Leon Cupra
Chaz
Hi,
I have been having some trouble with my leon cupra stuttering. I thought it was down to the N75 valve. I went a bought one and changed it. When I took the car out for a test drive after, it was still fluttering on the boost but this time the CEL came on.
I ran it through VAG COM and got the following.
2 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-00 - -
16686 - Cylinder 2 Misfire Detected
P0302 - 35-00 - -
Readiness: 0000 0000
I guess this just means that the coil is going/gone on cylinder 2. Do I need to change them all or just the one?
Also,,, which cylinder is cylinder 2.
Paul
Chaz
ok. Can I use any coil pack? I think they are up to revision R and am sure mine are about J (I think). So do they all have to be at the same revision?
Do you know what the part number is?
Which is cylinder 2?
Big_daddy
Going going gone.....
Oct 20, 2006
3,930
Brummy
Im not sure one which coil pack, do a search but check with your dealer for the part number.
From
Left 1 2 3 4 Right
