STUPID locking system
Seat slag
11
As all ibiza mk2 owners know, the central locking system is completely crud.
Ive had problems with mine ever since ive owned it. Does any1 out there know of a modification or golf mk4 conversion out there. Sometimes it makes me want 2 sell the car but i wont let it get the better of me.
Any help would be greatly appreciated.
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
you wanna read my escapades with it :lol:
what problems you having ?
i considered a universal electric kit but to be honest i couldn't be arsed to wire it all in
if the pump is working (osr 1/4 panel) there isn't much goes wrong with em apart from joints coming apart somewhere
surreyfull
148
Portsmouth
i have spent weeks trying to locate where a joint has come loose on mine to get the central locking working again.... no hope as of yet. dont let it beat you!
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
one trick i have learnt after my kid stuck an air line down the pipes while the motor was out (dont do it btw) is to check the clear shaft seal is wrapped over the boot lock solenoid properly, seems to the weakest spot so far
and make sure the pipe into the compressor is RIGHT OVER as they feel good but never seem to lock in easily
from the junction in the OSR 1/4 (behind the rear lamp)
red is fuel flap solenoid (common to leak)
blue is doors
black is boot lock
green is supply from motor to junction pipe
pop em off one by one and test by suck/blow down em doesn't take much pressure to make em work and a scrap bit of washer pipe or fuel hose is handy unless you can squeeze a small childs head in the corner as i had no pipe to hand :p
Seat slag
11
My problem at the moment is that a fuse remains on blowing everytime i replace it.
Its the fuse the controls the central locking pump, interior light and clock.
Im unsure if its a bad earth or a faulty cable. Has any1 experienced this???
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
main earths at the rear of the car are in the same area by the lights etc and the pump itself
OSR 1/4 panel inside the boot in a foam box - just follow the coloured pipes from behind the rear light
small wiring plug to disconnect to test the circuit after and the pump for a dead short while you are at it
if still bad circuit remove and test the interior light as the delay circuit board might have fused ?
can't think of much else connected to it apart from possibly maybe stereo +12v? not replaced it recently and caught a wire or got one mixed up ?
