I would guess that the "strut insert" being referred to is the damper itself. The bottom end of the damper is inserted into the tob of the hub and clamped tight.
i have a knocking (metallic and very annoying) sounds like disc being hit with hammer
and did it when i dropped car down off jack on saturday while checking the wishbone bolts were tight.
i have tried all kinds and it's pointing at strut - it was replaced a couple of months ago
and the knocking only happens at slow speeds and when turning or parking
someone on skoda web site said this was their prob
Maybe that; I'd say other possible culprits could be the top suspension mounts/bearings, or perhaps the spring isn't sat correctly in it's lower platform and is moving on turns.
Well a Seat dealer managed to reassemble mine once without the top bearings in
Symptoms were steering being harder to turn, much clunking & scraping as I turned in tight manouvres, an amazing self-centring ability, and a slightly lower front end
ours is ok apart from the metallic clunk which we can predict now
it's at Arnold Clark in Newcastle now so hopefully today i'll get some news
of the good vareity
