Was under the car the other day, noticed a silver corrugated thing, kind of like a small radiator under the drivers seat, any ideas? 54 plate TDI Cupra.
It's a fuel cooler.
It cools the hot fuel returned from the engine before it goes to back the tank.
The fuel pump is driven by the camshaft, so is always delivering fuel.
Most of the time this will be more than is required, so it gets returned, but it picks up a lot of heat on it's travels through the cylinder head.
And it's positioning under the car isn't ideal for venting. I'm looking at fitting an additional cooler in direct airflow, so the return pipe goes through 2 coolers, not just one.![]()
Fuel temp is one input to the ECM, and hot fuel may result in retarded timing. At least that's my understanding, and I could be wrong.
Perhaps there is more than one return ?Not quite true I know muddy just over looked this, but the fuel tank has a pump which allways pumps fuel to the engine, whats not used goes back the tank via the fuel cooler. Put your hand on it after a run gets quite hot.
