Strange noise from center console - Help Needed For Diagnostic
Nam-uk
1,228
391
lancashire.
Check the air pollan box after removing the pollan filter , as ive had the sound damping foam come away inside that box and break down as it gets stuck in the fan the noise made it sound was the worst, there is also a sound damping foam pad underneath the flap you can to get your hand around the back to clean it off.. its the plastic covering that jams in the fan .. defiantly worth checking... i took it all off when that happened and hovered it all out as the foam breaks down like the door seal foam
May 10, 2023
Istanbul
A bit of old foam might have become dislodged and stuck. What happens if you put the fans on max?
Thanks for your reply, I'm not sure which foam you mean, but we replaced the old sponge (there wasn’t much left of it! 😅) earlier because the heating wasn’t really working. When I set the fans to maximum, the noise becomes less noticeable since the fans are quite loud, but I think the noise is still there.
Thanks for your reply, Worth checking this, As far I understand I can check all of this from pollen filter side right?
___________________________________________
Only thing I can be sure is, I'm driving this car more than 40.000km's this only happens when Its below 6-5 degrees celcius, It never happened on summer which I everyday use ac.
Battoussai
494
152
Portugal
Just a guess here - to narrow down all possibilities. I saw you have an aftermarket radio, maybe an wince or android one? These radios often come with a built in fan. Have you checked that? Maybe the fan's busted bearing is causing that noise.
Reactions: efezorba
May 10, 2023
Istanbul
Thanks for your reply, I completely removed radio before this is my first suspect when Its happened last winter, but not Its coming from the radio. I wish It was so I can throw it out from the window :LOL:
