strange heater characteristics
gazjones
now that the cold weather is hear ive noticed something strange about my heater. when i have the heater on hi to warm myself up and im driving along its fine lovely and hot but if i coast for a bit and let the engine idle it goes alot cooler, did think it was the engine cooling down during coasting. but i even does this when stationary so i have to verly lightly blip the throttle then full warmth comes back.
any ideas why id does this as the engine cant cool down that fast, only think i can think is if the heater is on full and engine is idling the water pump is not pumping fast enough to meet the demand of the heater.
cheers gaz
pine
76
Finland
I have similar probablems("manual climatronic"): during summer it could suddenly star heating, when it's supposed to cool and now when heating, I get cool breezes one's in a while. VAG/SEAT tech said that the little motors that move the linkage etc. are broken or kind of 'missfire'. Need to changed..haven't done it yet, waiting to either freeze to during winter or get the heat-treatment next summer..
rashcupra
MV AGUSTA & 1.8T DUB MK4
Oct 15, 2006
6,517
crawley
try bleeding your coolant system as air locks can cause the heaters to under acheive hot?warm air!
gazjones
thing is its ben serviced in last 2 months that should have been checked i would have thought worth a try though think ill ask seat if its normal
BIGAR
CHESTERFAIRIAN
Feb 5, 2006
218
CHESTERFAIRIANLAND
cheers gaz
That's right mate the water is pushed around the system via the water pump when you are on low revs the water pump is pumping at a slower rate, all cars have experience the same to a lessor/greater degree, its when you can get no heat in that's when you should start $hittin it.
moditsteve
i have a similar prob sometimes say i have it set to 21 it is warm but other times at the same temp its blowing out Cool air ?? very confusing (and yes this is when the car is warm lol ) i just turn theheaters up to compensate for the cool air coming in ;)
rashcupra
Oct 15, 2006
6,517
crawley
lol! could be your answer if it keeps playing up when you turn all your fans off do you still get air coming thro the faster i go the harder it gets its so annoying!!
