I'm kinda new to VAG-COM, but anyway. I took a full scan and it coughed up these three faults.
I also got these:
I find the two last ones strange.
Signal can't be too low, it's not like it's a battery in the transponder.
How can the key have incorrect programming? It starts the car!
If I try to clear these codes, and they won't clear, I take it it's something wrong somewhere?
Anyone wanna shed some light on this? Thanks.
VAG-COM said:18048 - Internal Control Module: EEPROM Error
P1640 - 35-10 - - - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
16955 - Brake Switch (F): Implausible Signal
P0571 - 35-10 - - - Intermittent
Readiness: 0000 0000
I also got these:
VAG-COM said:Address 17: Instruments
1 Fault Found:
01176 - Key
07-10 - Signal too Low - Intermittent
Address 46: Central Conv.
1 Fault Found:
01179 - Incorrect Key Programming
35-00 - -
