Sticking Rear Caliper
damo c
right got a little problem with my 2001 leon cupra, my drivers side rear caliper is sligtly stuck on, i have taken the wheel off to have a look and sprayed some wd-40 on it give it a tap with a rubber hammer and it was ok for about 5mins until i put the hand break on.
anyone have any ideas how to sort this problem
thanks
damo c
WeeJase
pert
Jun 2, 2001
8,595
sounds like its not returning properly,i'd get it off and give it a proper greasing mate.where the hand brake attaches it pivots inside the caliper,might be able to get some wd40 in there but you really need grease.
damo c
think thats a job for tomorrow then. so i just got to take the caliper off and greese up where the hand break cable is? just put my hand throught the wheel and seems as if the cable isnt returning. pushed on it and it moved about 2mm
thanks
damo c
WeeJase
pert
Jun 2, 2001
8,595
where the cable attaches is an arm. this is bolted to the side of the caliper and pivots back and forth as you apply/release the hand brake,crap gets under this and causes it to stick(did on my old ones anyway)this is where i'd suggest looking first ;)
damo c
cool cheers mate. i'll have a look in the morning and see if i can sort it. i'll post back after i have had a look, hopefully this will sort it
thanks
damo c
techie
Skoda Techie
Mar 22, 2003
5,438
Worcs
Is the caliper locked on?
Its more than likely the pads have got stuck on the carrier rather than a fault with the caliper itself. Unbolt the caliper and check the pads. Advise new pads and the metal contact shims. Make sure the carrier is really clean before rebuilding.
