Sticking calipers
Sep 20, 2006
756
Birmingham
How do you know if your calipers are sticking? What are the signs? Should there the car pull to one side under braking?
While driving last night I got a weird screech that kept disappearing when I braked.
toonfiend
Hail to the Plug!!!!
Jun 27, 2008
159
If your calipers are sticking your car will pull as the brake is effectivly applied all the time, a good way to check is to take it out and really hammer your brakes, then feel your wheels... if youve got a stuck caliper your wheel will be red hot, i dont just mean warm, that is normal, I mean mega hot!, so you cant hold your hand on it, its a pretty good indicator that something aint right.
Sep 20, 2006
756
Birmingham
Ok I've done the wheel temp test and I think the drivers side caliper is sticking. So I'm going to take the sliding pins off, give them a clean and see if that helps. Otherwise I'm guessing i'll have to replace the caliper?
When I do remove the pins do I use locktight before I put them back on?
j.cavo
8 valves of pure power
Aug 6, 2009
229
Liverpool
probliy seized the get old and just die
Big Anup
just make sure you put plenty of greese on it before you put it back.
